everthings dead 73 cb750
hondaluver
west salem wi
cleaned all conections still nothing it worked before I cleaned them fuses good I have power to main fuse both sides turn on switch nothing
I think the reply was referring to jumping the cylinder shaped starter solenoid the two larger posts with nuts. There might be a little arc when You do this. if it turns over the problem ls in the two smaller post wires or the solenoid it self. in which You will have to ring out the wires with test light or a meter. Use the scematics in the electrical print in the manual and work Your way from the battery.
bad wire issue between fuses and conector everything works but no spark cleaned points new plugs checked plug caps still no plug spark ill check kill switch next
