Results 1 to 6 of 6
  1. #1
    CB750 New Member Funkateer's Avatar
    Join Date
    Nov 2019
    Toronto
    Posts
    Trying to re-attach front brake calipers on 1982 CB750C
    Hey all,
    Pretty new around here, (first post), but I've been enjoying reading the forums.
    I've got a 1982 CB750C (Custom) with the dual front calipers... when I got it the calipers were in a box... so it's come time to re-attach them and I'm seeing that all the bolts are not also in the box.
    Most of the bolts I need I've been able to find online but I need two bolts described as FLANGE (8X48) 90180-MA5-771 and I can't seem to find anywhere with stock.
    Some say it's temporarily unavailable, one said it's been discontinued.
    Does anyone know where I can find one or have a suggestion for if it has been discontinued?
    Thanks so much!
  2. #2
    CB750 Guru amc49's Avatar
    Join Date
    Sep 2015
    Fort Worth TX.
    Posts
    2,696
    Likely NLA.
    8 mm. bolt maybe 1.25 thread and 2 inches long, add a washer under it to make the length closer to the 48 of the spec. At least 10.8 property class bolt. Ace Hardware will have them.
  3. #3
    Join Date
    Nov 2019
    Toronto
    Posts
    Would an 8x49 bolt work? Would I need to use a washer with it?
  4. #4
    Join Date
    Sep 2015
    Fort Worth TX.
    Posts
    2,696
    The washer spreads out the load a bit better than bolt head alone. FYI, a flange bolt is a hex head bolt with the washer molded with it to be round instead of 6 sided.
    Yes, that would likely work. Make sure the 1.25 thread pitch is correct by screwing bolt in by hand before putting the wrench to it. Most 8 on motorcycle are 1.25 but a few aren't.
  5. #5
    Join Date
    Nov 2019
    Toronto
    Posts
    Awesome and good to know... thanks!
  6. #6
    CB750 Enthusiast keges335's Avatar
    Join Date
    Dec 2018
    New Wilmington Pa
    Posts
    93
    Try a Honda Dealer that has parts locater And give him the # if he don"t have them,. He can tell you a Dealer that would,.,
Similar Threads
  1. Cb750fb calipers 1982
    By Andy888 in forum Frame / Suspension
    Last Post: 06-04-2019, 12:06 PM
  2. Replies: 0
    Last Post: 12-09-2014, 03:24 PM
  3. Wanted - 81 CB750C Front brake reservoir OR assembly
    By Superseca92 in forum Classifieds
    Last Post: 07-11-2014, 11:24 PM
  4. 1982 cb750c front brakes
    By larry6ft in forum The CB750 Garage
    Last Post: 05-30-2014, 10:52 AM
  5. Brake Calipers
    By zanthor in forum The CB750 Garage
    Last Post: 03-31-2014, 11:30 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
