Results 1 to 4 of 4
  1. #1
    CB750 Enthusiast mnvkngs65's Avatar
    Join Date
    Jul 2019
    Los Angeles
    Posts
    31
    cylinder base gasket - gasket sealant?
    Finishing the upper motor rebuild on my 73 cb750 and am a little nervous about the final steps failing (i.e. gasket leaks).
    I have a KP gasket set and was wondering if I should use any type of gasket sealant on the cylinder base gasket? The online company I bought it from advertised it does not need it so I'm inclined not to.
    Also, I purchased new APE cylinder studs and plan to torque them down to their recommended ft/lbs and then loosen them and retorque as many suggest.
    Do I need new nuts for the studs or can I use the old ones?
    Thanks for any help.
  2. #2
    Moderator dirtdigger's Avatar
    Join Date
    Feb 2012
    Black Hawk SD
    Posts
    2,869
    if the surfaces of the block and cylinder are clean with no nicks you shouldnt need any sealant. I tend to use Copper kote on the gaskets and have had no issues. Dont use silicone or RTV anywhere on these motors. Hondabond or equivalent or Copper Kote on certain gaskets. Pay attention to the head gasket material and quality. I only suggest using the graphite type material head gaskets. Many of the aftermarket head gaskets are a cheap hard gasket material, I have used them and they all leak at some point no matter what you do to them. For stock rebuilds I only suggest OEM honda or Cometic graphite head gasket.
    You can use the original cylinder nuts no problem with the APE studs.
  3. #3
    Join Date
    Jul 2019
    Los Angeles
    Posts
    31
    Dirtdigger, Happy New Year and Thanks!
  4. #4
    Join Date
    Feb 2012
    Black Hawk SD
    Posts
    2,869
    No problem. Happy New Year to you as well.
Similar Threads
  1. What gasket
    By Donovan_ge in forum Builds
    Last Post: 07-01-2019, 04:43 PM
  2. Replies: 1
    Last Post: 05-28-2016, 05:56 AM
  3. Which gasket do I need?
    By ryguy85 in forum The CB750 Garage
    Last Post: 02-29-2016, 06:39 AM
  4. Gasket sets, which is best?
    By pipeguy in forum Engine / Exhaust
    Last Post: 11-24-2015, 09:58 PM
  5. Internal additive for head gasket sealant
    By drluther in forum Engine / Exhaust
    Last Post: 02-28-2015, 10:39 AM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
