starter clutch diode/rectifier
It's a one way power flow device that stops power from running backwards in a circuit that has two powered legs where one being active can flow power backwards through the one that is not powered. Typically it is used somewhere between the clutch lever switch and the neutral switch that both activate the starter button circuit.
Location depends on model and year and you're talking like 25 different ones there. Often it can be somewhere near the battery.
