Results 1 to 10 of 10
  1. #1
    CB750 Enthusiast KIRBY's Avatar
    Join Date
    Oct 2019
    Abilene, Texas
    Posts
    46
  2. #2
    CB750 Guru amc49's Avatar
    Join Date
    Sep 2015
    Fort Worth TX.
    Posts
    2,601
    I for one do not know what you are looking for as your question is clearly answered in the last two vids. The middle one for sure.
  3. #3
    Join Date
    Oct 2019
    Abilene, Texas
    Posts
    46
    How do you connect to the end of the crankshaft, and take a shaft out the side of the crank case without oil leaking? Are there aftermarket kits for that?
  4. #4
    Join Date
    Sep 2015
    Fort Worth TX.
    Posts
    2,601
    Probably custom covers with seals supplied by the turbo company.
  5. #5
    Join Date
    Oct 2019
    Abilene, Texas
    Posts
    46
    Yeah, I could hook two engines together through those covers.
  6. #6
    CB750 Addict Medyo Bastos's Avatar
    Join Date
    Oct 2012
    Mid South
    Posts
    162
    Sent from my iPhone using Tapatalk
  7. #7
    Join Date
    Oct 2012
    Mid South
    Posts
    162
  8. #8
    Join Date
    Oct 2012
    Mid South
    Posts
    162
    The stock stator cover is drilled, and a seal put on. Notice the pic I posted.
  9. #9
    Join Date
    Oct 2012
    Mid South
    Posts
    162
  10. #10
    Join Date
    Oct 2019
    Abilene, Texas
    Posts
    46
    Thanks! I could use one one the right side of one engine, and the other on the left side of the other engine, orient them to face each other, weld or bolt a shaft that connects the ends of the crankshafts, and bolt a tube around the shaft to the bolt holes on each side.any oil that leaks could only go into the tube, and probably back into the engines.Click image for larger version.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
