Results 1 to 12 of 12
  1. #1
    CB750 Enthusiast KIRBY's Avatar
    Join Date
    Oct 2019
    Abilene, Texas
    Posts
    46
    Replace Vulnerable Primary Chains With Gears?
    I've been told that the most vulnerable part of a CB 750, when increasing power, are the primary chains. Has anyone considered replacing the primary chain sprockets with gears for higher power handling?
  2. #2
    CB750 Guru amc49's Avatar
    Join Date
    Sep 2015
    Fort Worth TX.
    Posts
    2,664
    There is a New Zealand roadracer that does it on the DOHC, but the conversion is super megabucks............
  3. #3
    Join Date
    Oct 2019
    Abilene, Texas
    Posts
    46
    So.....All my ideas are expensive.
  4. #4
    Moderator dirtdigger's Avatar
    Join Date
    Feb 2012
    Black Hawk SD
    Posts
    2,866
    It has been done on the sohc but again, gears are super expensive to have designed and built. On top of that you have to do something with the crank as it has sprocket not a gear.
  5. #5
    Join Date
    Sep 2015
    Fort Worth TX.
    Posts
    2,664
    The DOHC technically uses a sprocket too, but it is one for Morse Hy-Vo type timing chain. That type of sprocket can be made as a gear-to-gear connection one and what he did there, the gear would have slightly odd shaped teeth but works as a gear anyway.
    And yes, to answer a previous statement, one of the greatest problems with your ideas is that they all will be as expensive to make as a jet fighter. The ideas CAN be done in physicality, but it takes a corporation to be able to amortize the ideas enough to be worth it.
  6. #6
    CB750 Addict Medyo Bastos's Avatar
    Join Date
    Oct 2012
    Mid South
    Posts
    167
    Mirko is working on it here ~> https://r.tapatalk.com/shareLink?sha...0&share_type=t Geared Primary Drive
    Sent from my iPhone using Tapatalk
  7. #7
    Join Date
    Oct 2019
    Abilene, Texas
    Posts
    46
    With only 2 gears, doesn't he spin the gearbox backwards?
  8. #8
    CB750 Enthusiast leo750k's Avatar
    Join Date
    Jul 2019
    central florida
    Posts
    43
    my mother always used to say to me "Ya you have Champagne taste, on a beer pocket book"
  9. #9
    Join Date
    Sep 2015
    Fort Worth TX.
    Posts
    2,664
    You put an idler in the middle for a 3 gear train, that keeps the proper spinning direction in place.
    I envision problems with that SOHC design, the sprung hub is going to be an issue. The DOHC one survives by using much smaller damping mechanism there, and even that may be gone now to use just the clutch basket as the damper there. Can't say. The first one used the OEM shell and the outer disintegrated under hard power, the inside damper blades that were separated by the damper rubbers moved under big power to crack the whole thing up.
    You want a crank damper to absorb vibration, it stops crankshaft breakage, but you also want solid gears there to carry bigger power. The SOHC gear shown in the link is likely to break up under power, the spring damper renders it too weak.
  10. #10
    Join Date
    Oct 2019
    Abilene, Texas
    Posts
    46
    Quote Originally Posted by amc49 View Post
    Yes, but I don't see one in his design.
  11. #11
    Join Date
    Oct 2019
    Abilene, Texas
    Posts
    46
    Here's an idea. Remove the chain. Put a speciallyClick image for larger version.
Name:	Sprocket to Sprocket Idler.JPG
ID:	9177 engineered idler between the two primary sprockets. I know the relative sizes of the sprockets is wrong, but this is just to demonstrate the idler with teeth that fit the chain runs. If the chain teeth need reinforcing, the space between the two runs can be filled in by a split piece machined to match the sprocket teeth.
  12. #12
    Join Date
    Sep 2015
    Fort Worth TX.
    Posts
    2,664
    I do not grasp that last sentence at all.
    The pic there is how the DOHC does gear drive.
    In the link he mentions 'idler carrier' and how he is going to mount it more than once in the post, you have to understand that means a third gear, the other two need no carrier as they are part of either driver shaft or driven shaft.
    I was likely incorrect on the post 9, that gear shown with the springs is the clutch one thinking, you need some sort of shock absorption there. I'm not big though on how weak the hub there is, it should break pretty quick, there is not nearly enough metal support there.
Similar Threads
  1. Life expentancy of cam and primary chains
    By Chris in Dorset England in forum Engine / Exhaust
    Last Post: 07-22-2017, 02:09 PM
  2. Gears/clutch question
    By Oldrusty750f in forum Clutch
    Last Post: 06-12-2016, 04:35 AM
  3. Engine bogs down in switching gears
    By DSlo in forum The CB750 Garage
    Last Post: 05-04-2014, 12:53 PM
  4. Cam chains, your opinions?
    By broncomatt in forum The CB750 Garage
    Last Post: 09-11-2012, 07:23 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
