Results 1 to 12 of 12
  1. #1
    CB750 Enthusiast John Luke's Avatar
    Join Date
    Aug 2019
    Ashville
    Posts
    38
    LED lights on 81 CB750C
    Hey guys! Iím putting led lights on my 81 CB750C I have an led blinker relay and the led light. How do I wire them? I do have the diode if needed. Let me know how itís supposed to be wired up.
    Thanks!
  2. #2
    Join Date
    Aug 2019
    Ashville
    Posts
    38
    Iíd really appreciate any help
  3. #3
    CB750 Enthusiast NicksHonda's Avatar
    Join Date
    Apr 2018
    Sacramento, CA
    Posts
    45
    As I recall, I simply replaced my relay with the LED relay and put in LED bulbs in the factory outlets. Do you have something different?
    Havin' Fun in Sacramento!
    2006 BMW R1200RT
    1979 Honda CB750L
  4. #4
    CB750 Guru amc49's Avatar
    Join Date
    Sep 2015
    Fort Worth TX.
    Posts
    2,569
    The lights themselves are the diodes, any extra part there is a current reducing resistor, LEDs function on only about 3 volts of power. If the bulb does not have a resistor installed with it on 12 volt you must add your own.
  5. #5
    Join Date
    Aug 2019
    Ashville
    Posts
    38
    Here is a photo of how I have the headlight wiring set up. Do I have the bullet connectors on wrong?
  6. #6
    Join Date
    Aug 2019
    Ashville
    Posts
    38
    Apparently I canít post a photo
  7. #7
  8. #8
    Join Date
    Aug 2019
    Ashville
    Posts
    38
    Quote Originally Posted by John Luke View Post
    Sent from my iPhone using Tapatalk
  9. #9
    Join Date
    Aug 2019
    Ashville
    Posts
    38
    I know Iíve been double posting a lot but i just got Tapatalk and itís amazing plus I can post a video/photos for yíall.
    https://share.icloud.com/photos/0Tqh...RVeLJDgng#Home
    Thanks!
  10. #10
    Join Date
    Sep 2015
    Fort Worth TX.
    Posts
    2,569
    Sometimes I am so full of crap.........................beyond that the pic really does nothing there at all, grasping wiring issues is much more involved than 1 or 5 or maybe even 20 pics can ever make clear, the whole system has to be looked at in entirety to figure out where many of the problems are. The slightest small unseeming detail can be the killer there and right in plain view.
  11. #11
    Join Date
    Aug 2019
    Ashville
    Posts
    38
    Yeah, okay. But from the photos/video do I have most of the wiring connected correctly?
  12. #12
    Join Date
    Sep 2015
    Fort Worth TX.
    Posts
    2,569
    Absolutely no way to tell, I cannot accept that it is wired correctly based on your word, the ENTIRE system has to be checked once it proves out to not work correctly. For one your description of LED wiring is sadly lacking, I would have to have a pictured pinout schematic from the maker or test it myself to know.
    Most wiring of what you did there is normally inside the headlight shell and you are down by chassis and coil area. So, to begin with, wondering where the rest of the wiring is, and more importantly, in what way it was changed. Take the bleed into oil light and neutral, there is no way those circuits should even be touched yet you have power of some sort backfeeding into them, and they shouldn't even be joined never mind the bleed-in issue. So up to 3 things wrong there maybe. And not a clue as to how the rear signals were patched in making things impossible to say again. The point where you say 'I think I've wired this correctly'.........what can I say but how on earth can I guess at that bundle of non-stock wires with no pinout again, I have no clue as to what they are so not wired right in my view.
    This is one of those things that the internet often cannot touch with any degree of detail to fix, the subject must be moved through in a hundred places in minutes and doable by an expert there in person, he can never hope to do that online, the 'net cripples that. Your vid didn't touch 50 things I'd have to check there to OK it. What I tried to say in the previous post. I could easily fix it in person with the bike but no way here sitting in Texas, the limitations are too numerous and too great.
    And I have no trouble at all working on 5 miles of wire in a modern electronic car, but I absolutely MUST know what EVERY single wire does to avoid major damage there. I build computers, I would not even dare to power one up without knowing that every single wire is 100% correct, best way to blow one out there is.
    Sorry I don't have more but it is what it is...........you're looking for a 5 word answer when there is a 500 page book needed there.
Similar Threads
  1. K8 running lights and meter lights
    By Hunter1919 in forum Electrical
    Last Post: 08-17-2019, 07:43 AM
  2. LED indicators
    By Jimiboy in forum The CB750 Garage
    Last Post: 06-11-2019, 05:16 PM
  3. LED Brakelight
    By Skelee in forum Electrical
    Last Post: 05-14-2018, 01:54 PM
  4. LED conversion
    By Nolan618 in forum Electrical
    Last Post: 02-12-2018, 08:36 PM
  5. led lights on 1978 cb750k
    By mrtelec in forum Electrical
    Last Post: 01-19-2018, 04:23 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
