Results 1 to 4 of 4
  1. #1
    CB750 Addict dan1951's Avatar
    Join Date
    Sep 2013
    armada mi. 48005
    Posts
    333
    1971 sohc breather hose
    Hi everyone long time since I was on here, Anyway I have a lot of air coming from the tappet cover when running at idle I thought this pressure was released out the breather hose nothing comes from it if it is it is unnoticeable any help much appreciated. Thanks
  2. #2
    Join Date
    Sep 2013
    armada mi. 48005
    Posts
    333
    My mistake I removed the breather hose and have it hanging on the side of the bike there is a minimum amount of engine air discharging from it but it is nothing like removing a tappet cover.
  3. #3
    CB750 Guru amc49's Avatar
    Join Date
    Sep 2015
    Fort Worth TX.
    Posts
    2,695
    Confusion between true blowby and simple air displacement from pistons going up and down. A four cylinder moves air around a lot as one piston goes down and the one next to it goes up, the air swaps sides and in pairs. That is different from the true blowby which leaks past the rings and normally a much smaller amount.
    On true race bikes you can open up holes in the crankcases to let that left and right alternating air mass change places much easier, it's said to be worth up to 5 hp at extreme rpm.
  4. #4
    Join Date
    Sep 2013
    armada mi. 48005
    Posts
    333
    Thanks amc for the explaination.
Similar Threads
  1. Wanted - Crankcase breather hose and Tee for 1980 CB750K
    By saltracer in forum Classifieds
    Last Post: 10-19-2018, 05:08 PM
  2. For Sale - 1971 SOHC good basket case
    By samo in forum Classifieds
    Last Post: 08-12-2016, 10:07 AM
  3. Breather at front of engine?
    By chuckt in forum The DOHC Garage (1984+)
    Last Post: 08-04-2016, 06:43 AM
  4. Stock breather install
    By wa-chiss in forum Engine / Exhaust
    Last Post: 01-17-2014, 06:10 PM
  5. Oil always drips from my case breather...normal?
    By CB750-Bobber in forum The SOHC Garage (1969-1978)
    Last Post: 06-17-2012, 08:42 AM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
