Results 1 to 8 of 8
  1. #1
    CB750 Member llibellen's Avatar
    Join Date
    Jun 2019
    Akron, Ohio
    Posts
    1978 honda cb750k carbs
    I've been working on these 4 carbs since early summer. I bought a 4 carb rebulding kit & rebuilt them 3 months ago. When I start it up (only starts with full choke), gas pours out of the overflow (bottom of carbs). I have tried almost everything I can think of, but to no avail. I just ordered (& received) a second rebuild kit, but before I start rebuilding again I thought I'd check in here for help. I know there are a lot smarter people on this forum, so can someone help me please! Thanks, Bill
  2. #2
    CB750 Guru amc49's Avatar
    Join Date
    Sep 2015
    Fort Worth TX.
    Posts
    2,687
    If they run ethanol in your local fuel and the bike sits, then you can have that issue if bike sits as little as a week, the ethanol lets the needles stick. Past that, poor needles in some of the kits cause many issues like that. Many use cheap Chinese rubber tips that are not ethanol resistant and then they swell out of shape to not seal right.
    If the needle seats in carb body have corroded due to ethanol exposure then you likely never will stop the issue.
  3. #3
    Join Date
    Jun 2019
    Akron, Ohio
    Posts
    OK Thanks. Adjusted float valves to shut off gas intake, so I'm getting closer. I must not be looking in the right sites since I cannot find the m/m measurement for the floats setting & the screw "turns"for the needle valves. I must be looking in the wrong places. Maybe you could point me in the right direction. Thanks again.
  4. #4
    Join Date
    Sep 2015
    Fort Worth TX.
    Posts
    2,687
    http://manuals.sohc4.net/cb750k/
    You want the K1-K8 supplement, K8 is a '78 model. Go to the page between page 264 and 276, the manual is somewhat messed up as far as the pagination goes.
  5. #5
    Join Date
    Jun 2019
    Akron, Ohio
    Posts
    Thanks again & again. I think I can get everything from the K1-K8 supplement that you have provided. I didn't
    want to wear out my (newbie status) welcome, but I appreciate you're reply. I may or not need you in the future, LOL
    Thanks Again
  6. #6
    CB750 Member KRBJ's Avatar
    Join Date
    Jul 2019
    Fort Bragg
    Posts
    12
    The Honda factory manual has a few mistakes. In your case it says the slow jets are not renewable but they ARE and should be removed to clean them.
  7. #7
    CB750 Addict Medyo Bastos's Avatar
    Join Date
    Oct 2012
    Mid South
    Posts
    167
    Try here -> http://www.hondachopper.com/garage/c...carb_info.html
    Sent from my iPhone using Tapatalk
  8. #8
    Join Date
    Jun 2019
    Akron, Ohio
    Posts
    Click image for larger version.
ID:	9112 The supplement doesn't have the carb data that I need. These (attached) rubber washers came with the rebuild kit but I can't
    find any data on where they go. I wish I could leave all this to the pro's but nobody will touch it. All said if it's more than 20 yrs old, forget it.
Similar Threads
  1. Replies: 23
    Last Post: 06-21-2018, 06:27 AM
  2. Putting older version Carbs on 1978 CB750 k8
    By tdubsy in forum Carburetors / Fuel
    Last Post: 05-13-2018, 09:35 PM
  3. For Sale - 1978 Honda CB750K basket case $500
    By fivestring in forum Classifieds
    Last Post: 01-30-2016, 11:30 AM
  4. Replies: 2
    Last Post: 03-16-2015, 04:10 AM
  5. 1978 cb750 four k carbs.
    By fatoldo in forum Carburetors / Fuel
    Last Post: 02-26-2014, 03:45 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
