Results 1 to 4 of 4
  1. #1
    CB750 New Member EWScroggins's Avatar
    Join Date
    Jul 2019
    Idaho
    Posts
    Gauge cluster for CB900F
    Hey all,
    Iv'e got an 82' CB900F and I friggin love it. The previous owner had a lot of work done to it:
    V&H 4-1 Exhaust
    DynoJet the carbs
    fork seals
    new clutch
    led turn signals
    Rims from an 03' ZX9
    The rims are causing my headaches today. In short the speedo does not work since the newer rims are not equipped with teh proper set up to work with the analog speedo. I am currently using a GPS speedo app on my phone, but that is getting annoying. I've looked at a few options. So my question is this: What do you all reccomend (on a budget) and how hard will it be to wire in a digital setup with either a GPS based speedo or the magnetic speedo?
    I thought about going back to stock but I'd rather keep the ZX9 rims for better tires.
    Click image for larger version.
  2. #2
    CB750 Guru amc49's Avatar
    Join Date
    Sep 2015
    Fort Worth TX.
    Posts
    2,598
    Most used Honda CBR600 wheels to get big tires on them and then speedo works.
    If the VH pipe is the standard street one OK but if the supersport pipe they tend to crack super quick around the collector area, I would suggest adding another mount there to stabilize the shaking that makes the cracking happen. VH used some thinwall piping there. Lots of complaints and why they dropped the pipe.
    Run the valve clearances, nobody ever does it and what commonly kills the engines. Set them at .005" instead of .003", the engine will love you for it.
  3. #3
    Join Date
    Jul 2019
    Idaho
    Posts
    Haven't cracked the engine open yet. I know I need to monitor timing chain tension on these older DOHC's.
    Any particular years of CBR600 rims I should look for? I would love to keep the factory gauge setup if possible.
    Not sure what model V&H they are. First bike I've owned that had actual aftermarket pipes. I used to just mod the factory exhaust due to budget restrictions.
  4. #4
    Join Date
    Sep 2015
    Fort Worth TX.
    Posts
    2,598
    The header that does not break.
    https://www.ebay.com/p/Vance-Hines-1...nid=1907933686
    The one that does break.
    https://www.amazon.ca/Vance-Hines-Su.../dp/B000GV4RFC
    Go below and sign up for free, enough early DOHC stuff to choke a horse.
    http://www.cb1100f.net/
    You should be able to find what you need on the wheels.
Similar Threads
  1. 82 CB900f unresponsive under 4000rpm
    By Geno1 in forum Carburetors / Fuel
    Last Post: 11-17-2018, 05:43 PM
  2. Wiring cluster F@&$
    By Asphalt Cowboy in forum Electrical
    Last Post: 11-02-2017, 12:50 PM
  3. New Here/Looking at a CB900F
    By Wildman1024 in forum General Motorcycle Discussion
    Last Post: 06-19-2017, 08:36 PM
  4. Instrument cluster
    By jockster in forum The DOHC Garage (1984+)
    Last Post: 11-20-2015, 09:50 AM
  5. For Sale - '79 CB750F and '82 CB900F - WA
    By goayala in forum Classifieds
    Last Post: 06-25-2014, 02:42 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
