garbal
I'm at the end of my rope here, I have had the carbs off 5 times now, apart back together, apart, back together.
I've cleaned them ultrasonically for about 5 hours... blew everything out put them back together and back on and the problem persists.
My buddy keeps telling me it's dirt in the little passages... is this still possible. They looked very clean and I blew everything out... is this still
a carb problem or should I be looking elsewhere.
Firstly it used to bog out between 3 and 5000 rpm, if I pulled the choke it would light right up, now the choke doesn't even help, it just bogs and sputters at about 3-3500 rpm... that's it... runs perfect at idle but once you open it up ... it just coughs and sputters... let off ... fine,
Anyone else have a similar issue. I'm hoping someone has and has found an answer to this issue. I've been told I need to clean the carbs again...
This is my second set of bodies... what am I missing?
Also... New to the forum. Looking forward to meeting and hearing from you guys!
Take care,
Garbal.
Take care,
Garbal.
