linkage between 2nd & 3rd carbs
llibellen
Akron, Ohio
ok, so I'm not the smartest carb rebuilder. (Not even close) I bought my CB750k in 1978 off the showroom floor & a couple of months ago decided to rebuild the carbs. I got the rebuild kits & went ahead with the rebuild. I'm enclosing a picture of my choke linkage since I know it's not right. Also (since they're mounted on the engine) do I have to pull the carbs to get the choke linkage right? And can anybody send me a pix of the correct hookup?
You just may not have the small gauge choke spring hooked up. The split fork on the right carb in your pic has a notch cut into the lower fork tine there, the smaller gauge spring on the left side carb hooks onto that notch. It makes the left pair of choke butterflies follow the right pair.
Looks like you're right. Appreciate your help. Thanks
