Results 1 to 4 of 4
  1. #1
    CB750 Member zimzim's Avatar
    Join Date
    Apr 2019
    Saskatoon
    Posts
    Oil filter housing all messed up
    The housing for my oil filter appears to be all kinds of messed up. Where there should be a 17mm nut, there is something in between 1/2" and 12mm, and I can't see how it is supposed to spin. Has the previous owner effectively ruined my ability to change the oil filter or is there something I'm missing?
    https://photos.app.goo.gl/8adSXFnA1BuJYTDfA
  2. #2
    CB750 Addict Medyo Bastos's Avatar
    Join Date
    Oct 2012
    Mid South
    Posts
    140
    Lefty loosely, righty tighty
    Sent from my iPhone using Tapatalk
  3. #3
    Join Date
    Apr 2019
    Saskatoon
    Posts
    Does this nut look normal? It's also an odd size, threaded on the inside, and there doesn't appear to be any planes of contact between it and the oil filter housing.
  4. #4
    CB750 Guru amc49's Avatar
    Join Date
    Sep 2015
    Fort Worth TX.
    Posts
    2,223
    Junk the center bolt there, counterclockwise to remove. Butcher at work there. Pull case and filter off and hope the other fitting the bolt goes into is not butchered as well.
    What normally goes there.........
    https://www.partsgiant.com/p327137-e...SABEgKfBPD_BwE
Similar Threads
  1. 1980 CB750F Ignition Housing - Oil seeping in
    By stevecr1 in forum The DOHC Garage (1979-1983)
    Last Post: 10-25-2017, 04:30 PM
  2. Stuck oil filter bolt and oil drain plug
    By Ford40 in forum The SOHC Garage (1969-1978)
    Last Post: 01-25-2017, 07:30 AM
  3. Oil path housing gasket?
    By CBGB in forum Engine / Exhaust
    Last Post: 09-06-2015, 09:50 PM
  4. Oil in distributor housing
    By raene in forum The CB750 Garage
    Last Post: 07-01-2014, 06:36 PM
  5. oil filter
    By grib72 in forum The CB750 Garage
    Last Post: 02-24-2014, 02:54 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
