Results 1 to 11 of 11
  1. #1
    CB750 Member NastyNate750's Avatar
    Join Date
    May 2019
    North Carolina
    Posts
    7
    Carbs for 79-82 dohc
    Just picked up a project bike, 79 750. Everything there and solid minus carbs. Anyone have any available? Thanks.
  2. #2
    Moderator dirtdigger's Avatar
    Join Date
    Feb 2012
    Black Hawk SD
    Posts
    2,962
    ebay will be your best bet if you really want stock carbs.
  3. #3
    Join Date
    May 2019
    North Carolina
    Posts
    7
    That's where I've been looking. I have the 750k series. Are there interchangeable carbs or should I look specifically for carbs from a 750k? I plan on rebuilding/jetting to run pods or stacks.
  4. #4
    CB750 Guru amc49's Avatar
    Join Date
    Sep 2015
    Fort Worth TX.
    Posts
    3,008
    Anything that fits that year range 750, K, or C, or F does not matter, bigger off 900 or 1100 will work but harder to, the 1100 ones do not have the primary main system that a 750 needs to work right. The carbs being CV type do NOT respond well to pods or any other air filter than OEM so expect trouble doing it.
    Run the valve clearances, most of the time the carbs are off due to problems with the valves leaking.
  5. #5
    Join Date
    May 2019
    North Carolina
    Posts
    7
    Any idea if carbs off of an 82 nighthawk 750 will work?
  6. #6
    Join Date
    Sep 2015
    Fort Worth TX.
    Posts
    3,008
    Yes, they will work fine.
  7. #7
    Join Date
    May 2019
    North Carolina
    Posts
    7
    Will VB44C carbs work?. From what I have seen those were on the 650. I want to keep my original boots because they are in good shape.
  8. #8
    Join Date
    May 2019
    North Carolina
    Posts
    7
    Found carbs.
  9. #9
    Join Date
    Sep 2015
    Fort Worth TX.
    Posts
    3,008
    Hope it's not the 650 ones, the spread and centers will be different and the jetting will not be correct as the engine is totally different. The carbs themselves are the same type but too small for 750 which is 30mm., the 650 uses 28mm. Thinking no accel pumps on the 650 either, could be wrong there.
  10. #10
    CB750 New Member cber's Avatar
    Join Date
    Jul 2019
    ny
    Posts
    check classified. i posted keihin 4 carbs, ultrasonically cleaned, factory jets, no issue runs very smooth. off a 1981 cb750c.
  11. #11
    Join Date
    Jul 2019
    ny
    Posts
    i also have oem seat, mufflers/headers, airbox. all in excellent condition. Muffler has been polished & ready to be bolted on.
Similar Threads
  1. Replies: 6
    Last Post: 10-28-2015, 06:58 PM
  2. Carbs Overflowing, 1980 750F, VB42 carbs
    By Ricebiker in forum Carburetors / Fuel
    Last Post: 06-12-2015, 06:21 PM
  3. Ditching stock carbs for 2 mikuni bs38's on a DOHC
    By tmilio in forum Carburetors / Fuel
    Last Post: 04-19-2015, 07:52 PM
  4. unique dohc carbs???
    By he_revolts in forum The CB750 Garage
    Last Post: 05-24-2014, 07:23 PM
  5. Anyone running RS34 Carbs on their DOHC? Or CR31's
    By The Menace in forum The CB750 Garage
    Last Post: 12-23-2013, 08:06 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
