Results 1 to 10 of 10
  1. #1
    CB750 Member NicksHonda's Avatar
    Join Date
    Apr 2018
    Sacramento, CA
    Posts
    21
    Under 4K hesitation
    Under 4K whether blipping the throttle or under load it hesitates. After 4K it takes off and runs great.
    Stock 1979 CB750L with 15,442 miles.
    It starts right up from cold with the choke on. After a little while I can pretty soon push the choke in and it idles fine.
    I sprayed WD40 all around the intake boots and no noticeable change in RPM.
    I have the same cylinder pressure on all cylinders.
    I rebuilt the carbs three times now. I double checked the float and they are all at 15mm.
    I noticed on mine, my #2 cylinder is running much cooler than the other cylinders. After it runs for a while, if I spray a little fluid on the pipes, the other three burn the water right off and sizzle. #2 doesn't sizzle so much.
    I pulled the plugs and the #2 plug was wet with gas. I changed the plugs.
    When I cleaned my carbs I found the accelerator pump pumps (what seems like) a lot of fuel.
    I was thinking maybe mine needs a throttle sync. I have heard from other forums you shouldn't have to sync the carbs. I have a stock 1979 CB750L with stock air cleaner. I found my pilot jets seem to run well at 1 3/4 out on all the carbs. I have the yellow mark on the carb nuts for the butterflies. Makes me think it has never had a sync done.
    I swapped ignition wires between #2 and #3. No change in #2 cylinder temp.
    I'm thinking it MIGHT be a tight valve on #2, or it needs throttle sync.
    Any other input besides swapping carbs with another brand?
    Thanks in advance.
    Nick
    Havin' Fun in Sacramento!
    2006 BMW R1200RT
    2002 Honda CBR954RR
    1979 Honda CB750L
  2. #2
    CB750 Addict pidjones's Avatar
    Join Date
    Sep 2018
    East TN
    Posts
    239
    If you've never checked them, you probably have tight valves on several cylinders. Check your compression and valve clearance. If you have really rebuilt (which requires splitting the rack) the carbs and not balanced them then yes, you need to balance them - at least a bench balance which gets them very close. Get SeanG's carb rebuild document.
    "Love 'em all.... Let GOD sort 'em out!"
  3. #3
    Join Date
    Apr 2018
    Sacramento, CA
    Posts
    21
    They are all tight. I can get my .0015 in all of them. I can not get .002 in any of them. Getting the tool tomorrow (hopefully) to get the shims out. I am guessing they are all stock at .280. I will find out before I order shims. Joy. I was hoping to order a kit of shims, but that looks really expensive. Then again, at $7 each I will need eight of them, that's $56.
    2006 BMW R1200RT
    2002 Honda CBR954RR
    1979 Honda CB750L
  4. #4
    Join Date
    Sep 2018
    East TN
    Posts
    239
    You can usually find them for $6 on ebay. Sometimes a bunch for not much.
  5. #5
    Moderator dirtdigger's Avatar
    Join Date
    Feb 2012
    Black Hawk SD
    Posts
    2,734
    You need to use .004 to .006 for valve clearance not honda spec. So you want to hit .005" You also will need shims for 16 valves not 8 as the dohc is a 4 valve per cylinder. There is no "stock" shim size they will be whatever was needed to get the clearance. You will have to remove all the shims so you can figure out what size each individual valve needs.
  6. #6
    Join Date
    Sep 2018
    East TN
    Posts
    239
    And, please don't rotate the cams without shims in all of the buckets!
  7. #7
    Join Date
    Apr 2018
    Sacramento, CA
    Posts
    21
    Ok. So Iím measuring in mm. Youíre telling me to measure in inches by your quote marks. Correct? .04 inches is .10 mm.
    My clymer manual says .08 mm gap. So a wee bit bigger.
    Fun find, my shims show 290 mark and measure at 2.80mm. One has a mark of 300 and is measuring at 2.80 mm. Sounds like I need a few 2.70 mm and a few 2.60mm.
    Iím off to measure the rest.
  8. #8
    Join Date
    Apr 2018
    Sacramento, CA
    Posts
    21
    I see I used inches to measure the gap in my first thread. Sorry about that. I plan to use mm going forward. As such, I can get a .04 mm in all of them. I can not get a .05 mm in any of them.
    Thanks.
  9. #9
    Join Date
    Sep 2018
    East TN
    Posts
    239
    I've never seen a shim over .03 off.
  10. #10
    Join Date
    Apr 2018
    Sacramento, CA
    Posts
    21
    I better check my mic. Thanks.
Similar Threads
  1. Hesitation when bliping the throttle
    By vintagesportbikes in forum Carburetors / Fuel
    Last Post: 04-13-2019, 03:03 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
