not sure where to go next
I put in a new battery and all the bike does is click
Check all of the connections and starter solenoid. If it's only clicking sounds like solenoid but do a check on the voltage in the battery. Just cause it's a new battery could be down in voltage...try jumping it if goes on a jump then the battery is low if it just clicks start checking wiring and solenoid. Electrical problems are a nightmare but time and money will cure them....and patients
Solenoids fail. Wiring connections go bad, particularly around the corrosive atmosphere around the battery. If you have a DVM and know how to use it, check voltage at the Bat pole on the solenoid while trying to start, then the Mot pole, then the starter input. One of these will probably show low voltage.
