Results 1 to 5 of 5
  1. #1
    CB750 New Member Cjh750's Avatar
    Join Date
    Jan 2017
    Conway, SC
    Posts
    Uneven choke plates
    Click image for larger version.
    I have inherited this 73 CB750 and I'm in the process of bringing it back to life. I bought the carb rebuild kit and have the carbs off. As I was operating the choke lever I noticed that only the #1 choke plate would bottom out, the others would not and kinda float loosely. Pretty sure they should bottom out as well!? Is there an adjustment for this?
    Thanks in advance!
  2. #2
    Moderator dirtdigger's Avatar
    Join Date
    Feb 2012
    Black Hawk SD
    Posts
    2,715
    Yes they all should close. Look on the linkages connecting the chokes...they are threaded for adjustment.
  3. #3
    Join Date
    Jan 2017
    Conway, SC
    Posts
    Thank ya...I will work on it.
  4. #4
    Join Date
    Jan 2017
    Conway, SC
    Posts
    that did it...thanks dirtdigger!
  5. #5
    Join Date
    Feb 2012
    Black Hawk SD
    Posts
    2,715
    no problem
Similar Threads
  1. Number of Plates and Disks
    By JamesC in forum Clutch
    Last Post: 02-04-2019, 07:41 AM
  2. Throttle and Choke carb plates.
    By keges335 in forum The CB750 Garage
    Last Post: 01-24-2019, 06:30 AM
  3. Billet Clutch Lifter Plates For CB750
    By budman in forum Shops
    Last Post: 07-07-2017, 01:05 PM
  4. Hard clutch not engaging friction plates
    By crietti in forum Clutch
    Last Post: 02-20-2016, 08:23 AM
  5. Uneven Idle?
    By DanBarregarye in forum Carburetors / Fuel
    Last Post: 04-21-2014, 03:47 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
