Results 1 to 15 of 15
Thread: Sprung a leak
  1. #1
    CB750 Addict Skelee's Avatar
    Join Date
    Nov 2017
    Hamilton, Canada
    Posts
    161
    Sprung a leak
    I pulled into work. I noticed fuel leaking from the end of the closed carb? Any ideas where. I dont have many tools on hand.
    Sent from my SM-A520W using Tapatalk
  2. #2
    Join Date
    Nov 2017
    Hamilton, Canada
    Posts
    161
    Only 1 carb is leaking. The 3rd one from left. I am guessing float problem
  3. #3
    Old Bike Nerd grepper's Avatar
    Join Date
    Oct 2012
    Lowell, MI
    Posts
    467
    Quote Originally Posted by Skelee View Post
    Most Likely,
    you can try the carb drain screw and wash out what ever is obstructing the float valve from closing all the way. I've had that work. Or tap the carb with the handle of a screw diver, that might stop the leak. Or, just use the petcock to turn off the gas till you can get to cleaning the carbs.
    Drive fast and take chances
  4. #4
    Join Date
    Nov 2017
    Hamilton, Canada
    Posts
    161
    The carbs have no drain hoses. Should i add some?
  5. #5
    Join Date
    Oct 2012
    Lowell, MI
    Posts
    467
    That's up to you, that or a dish or rag to keep from making a mess.
    Sent from my XT1254 using Tapatalk
  6. #6
    Join Date
    Nov 2017
    Hamilton, Canada
    Posts
    161
    https://youtu.be/LnL8oYWAcbI
  7. #7
    Join Date
    Oct 2012
    Lowell, MI
    Posts
    467
    Yup, looks like the float valve is not sealing. Could be some junk in there keeping it from sealing, the seat or needle has corrosion, or you could have a hole in your float, keeping it from floating.
  8. #8
    Join Date
    Nov 2017
    Hamilton, Canada
    Posts
    161
    Finally took carbs out. Gave them good cleaning. No longer leak. However. Hell of a time getting the air box side all connected. I tried everything i know. Any suggestions i looked at youtube and noyhing works for me.
  9. #9
    CB750 Addict Wez_'s Avatar
    Join Date
    Apr 2017
    Enfield, CT
    Posts
    318
    What's preventing it from going on?
  10. #10
    Join Date
    Nov 2017
    Hamilton, Canada
    Posts
    161
    I cant seem to get them on, the slip off on side or i get one side only. I sprayed wd40. I moved air box back.
  11. #11
    Join Date
    Oct 2012
    Lowell, MI
    Posts
    467
    They are a bitch to get on. I Actually ended up using a ratchet strap around the back of the air box, all the way around the engine to get them on.
  12. #12
    Join Date
    Nov 2017
    Hamilton, Canada
    Posts
    161
    I gave up. Took bike to shop. See how much i get hosed for
  13. #13
    Join Date
    Nov 2017
    Hamilton, Canada
    Posts
    161
    back on the rode!
  14. #14
    CB750 Enthusiast MotersickleBum's Avatar
    Join Date
    Nov 2018
    Florida
    Posts
    51
    i'm deeply disappointed in you, son...
  15. #15
    Join Date
    Nov 2017
    Hamilton, Canada
    Posts
    161
    After quote from shop. I fixed it myself!
    I used ratchet straps to help hold things and slow got it!
Similar Threads
  1. Oil Leak?
    By burnsie in forum General Motorcycle Discussion
    Last Post: 06-02-2017, 08:16 PM
  2. oil leak
    By Coxy in forum Engine / Exhaust
    Last Post: 05-02-2017, 11:44 PM
  3. Carb leak, Help!
    By sellsme in forum The SOHC Garage (1969-1978)
    Last Post: 09-29-2014, 02:01 PM
  4. Oil leak
    By greenmachine in forum The SOHC Garage (1969-1978)
    Last Post: 06-12-2014, 04:04 AM
  5. Oil pan leak, help
    By Brdeca in forum The CB750 Garage
    Last Post: 07-27-2013, 02:44 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
