Results 1 to 5 of 5
  1. #1
    CB750 New Member chauer89's Avatar
    Join Date
    Oct 2017
    Connecticut
    Posts
    Updating Reg/Rec for a Lithium Battery
    Hey,
    An un-informed person on electrics here. I've read it's necessary to update your regulator/rectifier to a modern compatible one when replacing your battery with a modern lithium one. I've got an 80' 750k and bought an antigravity 8-cell. (https://shop.antigravitybatteries.co...ge-1/#comments)
    I'm curious to know if this reg/rect should be compatible with the new battery. (https://ricksmotorsportelectrics.com...gulator-14_103)
    I called antigravity and they said the voltage required for the battery is 12V and the reg/rect has a voltage set point of 14V +/- .2. Will this reg/rect work?
  2. #2
    CB750 Addict Skelee's Avatar
    Join Date
    Nov 2017
    Hamilton, Canada
    Posts
    127
    I would say ask gravity for recommendation for rectified
    Sent from my SM-A520W using Tapatalk
  3. #3
    CB750 Addict Wez_'s Avatar
    Join Date
    Apr 2017
    Enfield, CT
    Posts
    274
    Well from what I researched, a BMS or battery management system is needed. If you have an alternator, regulator/rectifier then you have a "BMS" lithium ion battery manufacturers are trying to capitalize on revenue. They wont say, "not compatible with X style charging systems" because X wont buy their product. I think the older style bikes equipped with kick starters, points and perhaps no alternator (someone correct me if im wrong here) would be the style charging system that would drain the battery.
    The $105 rectifier that you linked is probably equipped with better components than were available 40 years ago, I would try purchase it. I think most charging systems are set at 13.5 V where that one is set to 14 V. So it seems to keep the battery charged slightly higher. It likely will be a more efficient component. The LiFePO4 batteries seem to offer lots of electrical "torque" they are great engine starters and will get warm after frequent cranking due to their delivery of electrical current. They are much stronger crankers that AGM batteries, but they down side is heat/drainage. Your regulator/rectifier will charge it back up in it's stock form. That upgraded rectifier might make it better.
    Do I have a lithum battery? yes. Did I upgrade my regulator/rectifier? no. Does it crank and power all loads? yes. Does the battery drain after a few rides? no. Is my engine stock? yes. Cranks right up like no signs of drainage. Did I also purchase the correct LiFePO tender? yes
  4. #4
    Join Date
    Oct 2017
    Connecticut
    Posts
    Thanks for the additional info, I appreciate it.
  5. #5
    Join Date
    Apr 2017
    Enfield, CT
    Posts
    274
    no problem....im no expert on these matters but I'm simply walking the same path as you all trying to upgrade my moto.
Similar Threads
  1. Lithium batteries! INFO
    By Tronco in forum General Motorcycle Discussion
    Last Post: 10-31-2017, 05:46 PM
  2. For Sale - Voltage Reg / Rectifiers *NEW US MADE* $6.00 to $20.00
    By AaronKaufman750 in forum Classifieds
    Last Post: 09-20-2017, 11:03 AM
  3. Battery Help
    By CivilPenny in forum The CB750 Garage
    Last Post: 07-15-2015, 10:16 AM
  4. Lithium Battery Melted....
    By motoshed in forum Electrical
    Last Post: 06-04-2015, 07:11 PM
  5. rec tifier regulator combo wiring
    By rbeesley1 in forum The CB750 Garage
    Last Post: 06-09-2014, 06:26 AM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
