Results 1 to 12 of 12
  1. #1
    CB750 New Member El Dub's Avatar
    Join Date
    Mar 2018
    West Sacramento
    Posts
    Rear Fairings removal
    Hello - I just purchased my first motorcycle - a 1995 CB750 - I love it. I am looking to install a Shad top case. As you can see in the picture, there is already a seat back with a rack. In order to remove it, I have to take off the rear fairing. I noticed that the rack is held in place by the same bolts that hold the shock absorbers in place and I am worried that the shocks will come off if I remove that bolt. Can anybody tell me if this is true and, if so, how to avoid a problem before it starts. Thanks for helping!Click image for larger version.
  2. #2
    CB750 Guru amc49's Avatar
    Join Date
    Sep 2015
    Fort Worth TX.
    Posts
    3,389
    More than likely stud and nut used there rather than bolts. Nut comes off while stud continues to hold shock in place.
  3. #3
    Join Date
    Mar 2018
    West Sacramento
    Posts
    Great - thanks for the information. I appreciate the help.
  4. #4
    CB750 New Member eps1234's Avatar
    Join Date
    Apr 2020
    Chicago
    Posts
    did this work?
    Quote Originally Posted by El Dub View Post
    Just making sure it worked... I think I have to take the rear fairing off as well and wanted to make sure since it looks like we have the same set up.
  5. #5
    CB750 New Member DJOEZZZZ's Avatar
    Join Date
    Oct 2020
    Netherlands
    Posts
    @eps1234 I'm interested as well. It looks like I have to remove the rear fairing and I would like to know if the shocks are kept in place by a stud or not. Have you tried removing it yet? If so, would you please be so kind to share your findings?
  6. #6
    Join Date
    Sep 2015
    Fort Worth TX.
    Posts
    3,389
    https://moto-odejda.ru/file/HondaNithawk.pdf
    Page 2-4.
    Seat has to come off first.
  7. #7
    Join Date
    Oct 2020
    Netherlands
    Posts
    Thnx ... Found this file as well. Unfortunately it doesn't tell me if the shocks remain in place when the bolts are removed. I can't seem to find anything written about this online. Even though the question has been raised a couple of times.
  8. #8
    Join Date
    Sep 2015
    Fort Worth TX.
    Posts
    3,389
    ???? No rocket science there..........
    Bike on centerstand and rear tire slightly off ground. Remove ONE top shock bolt only, the other side shock will still support the wheel and arm but it will likely drop a little bit. Loosen lower end shock bolt on the first side and see if the top of shock is firmly still attached at top. Grab top end and try to swing it. Should easily come up with an answer there.
  9. #9
    Join Date
    Oct 2020
    Netherlands
    Posts
    Thnx. I don't have a centre stand though. Will try to find a solution.
    Verstuurd vanaf mijn SM-G960F met Tapatalk
  10. #10
    Join Date
    Sep 2015
    Fort Worth TX.
    Posts
    3,389
    People should keep them, I do for a tool as I usually put header on that requires it to come off. But I keep the stand to slip in place to get back wheel off the ground if needed for work. Like having a jack for car.
  11. #11
    Join Date
    Oct 2020
    Netherlands
    Posts
    I agree, but the centre stand wasn't on the bike when I bought it. I would buy one, but I'm not sure if I want to keep the bike as my regular bike in the near future. I'm considering buying something "new", although a lot of people people who had a nighthawk 750 regret the fact they sold it. Need more time to weigh my options
  12. #12
    Join Date
    Sep 2015
    Fort Worth TX.
    Posts
    3,389
    The reply was to others, I figured already you didn't have yours.
Similar Threads
  1. 83 nighthawk CB 750, rear wheel removal
    By Gsjj in forum The DOHC Garage (1979-1983)
    Last Post: 12-02-2017, 07:47 PM
  2. Make Offer - vetter fairings luggage rack engine guard
    By Jgaray in forum Classifieds
    Last Post: 04-29-2017, 09:05 PM
  3. Odd CB750 Wheels, Rear Brakes, and Rear Sprocket
    By Chambers in forum The CB750 Garage
    Last Post: 01-23-2016, 08:39 PM
  4. Rust Removal
    By Nam Point Man in forum The SOHC Garage (1969-1978)
    Last Post: 06-13-2015, 03:05 PM
  5. Rear Wheel Bearing Removal
    By Steve L in forum The CB750 Garage
    Last Post: 02-01-2015, 08:35 AM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
