Hillbilly Bike
I bought this 750C 6 months ago and over the winter I modified in to what you see here..Cut off unneeded brackets....96 VRF750 front forks, 93 VRF 17 inch front wheel with larger 96 brake discs and calipers...late 80's VRF rear wheel and disc brake. 71 Triumph 650 rear fender..Yamaha XS750 gas tank...90 Sportster solo seat...Home made rear set pegs and controls. Needed to spread the rear swing arm to get the rear wheel where it belonged.A late 80's 20 MM speedo drive is on the rear axle, no room on the from to install it...I pressed out the 750C steering stem and used it for the 96 VRF front forks. As it sits , 26 degrees rake and 4.2 inches of trail .I removed the engine to replace the gaskets, new rings and valve guide seals...Dyno Jet kit to deal with the pods..A few more minor things to clean up...It's not everyone's style but I like it...
