Unusual rear wheel hub
kz456
California
I'm new to the form here and this is my 1st post. I have a 70 CB750 that someone has put a 16 inch rear wheel on. I'm looking at the rear wheel hub and it doesn't look like anything I've ever seen before. It seems to use the OEM break plate and sprocket carrier/dampers but the hub is completely smooth. There are no ribs. It seems it could maybe be steel. A magnet will loosely cling to it but perhaps it's just from the sightly dull chrome type plating. It has the typical Honda looking minimum drum diameter cast on the inside of the brake drum. Has anyone ever seen anything like this? Thanks
Looking closer at this and other wheels it appears someone has shaved the ribs off the inside spool and then chrome plated this...
