Clutch switch
Windy
33
Lincolnshire, United Kingdom
Hi, I'm sorting out a 1982 FZ electrics at the moment by junking the original wiring loom & making a simplified one.
I want to clean up the handlebars and have come across a switch in the clutch lever housing.
Firstly, what is its purpose and can I just disconnect it & get rid without any problems?
As usual, your help will be greatly appreciated.
Cheers Windy
Clutch switch is so you have to pull clutch lever before the starter will turn the engine over when in gear. Not sure if you can just unplug it or if you need to jump it.
Cheers Windy
You will have to bridge it out. You may have a problem with the one way diode as that is part of the clutch switch circuit.
