Removed my carbs from the soaking tub and this little washer was left behind...halp!
fuhgeddaboudit
11
California
Anybody know where this little dude belongs?
Thanks!
It looks the the little washer that goes under the spring that is on the idle mixture screw. There should have been a rubber o-ring then the washer then the spring then the screw. If you didn't take the o-ring out before going in the carb cleaner then the o-ring is probably bad now as carb clean eats away and swells up rubber parts. Thats what it looks like anyway.
