About Motor
Kevin S
alabama
Hello. I been wanting one for along time and finally found one. Its a 73 with sohc 750 motor. It runs good but I plan to strip entire bike and redo everything over time. My biggest question is where is oil dipstick located? Thanks for the help
Nice find [emoji106]No dipstick, pull the oil tank cap and watch the oil circulating while you run the engine. You should see the tank about 1/2 full while the engine is running
Stock oil tank had the dipstick on the oil tank cap. Some aftermarket oiltanks have caps with dipsticks, You can find some aftermarket caps with dipsticks, kind of depends on the style of cap your tank takes. I make my own tanks then I can use caps with dipsticks and I can make sure I have enough capacity and the oil line fittings are big enough.
