Cb750 front form length
shaunbe
65
del rio
Hello all, I have a set of complete forks from a 71 that I am going to put on my 76 cb750 but for some reason the left fork appears to be longer than the right fork, is this how they all are or was one side probably replaced with a different size fork tube?
They should be the same. Optical illusion can make one with disc look shorter. One tube could be bent too and not compressing all the way.
The forks are complete sitting on the ground not mounted to anything, the forks are all the way extended only thing holding them to each other is the fender.
Is there a problem using the 76 fork tubes and the 71 legs? I'm asking because I'm missing the caliper for the 76 legs and the 71 legs have everything
