Results 1 to 7 of 7
  1. #1
    CB750 New Member Anthonyt's Avatar
    Join Date
    Aug 2016
    Austin texas
    Posts
    Exclamation Weak front break
    Hey guys, I am new to the forum, just bought a 1979 cb750, and the front break is really weak looking to fix it but don't know how. I know literally nothing about bikes just to let yall know. where do i start? what do I tackle first? What am I looking for?
    thanks guys.
  2. #2
    CB750 Guru amc49's Avatar
    Join Date
    Sep 2015
    Fort Worth TX.
    Posts
    2,909
    SOHC or DOHC? Some get the years wrong. One disc or two? "Really weak' quite frankly says nothing other than it doesn't work, detail that better. Does lever get tight when you squeeze it or seem to give way? Did you check for brake fluid in it? Exact model and year is on a plate up on the steering head.
  3. #3
    Join Date
    Aug 2016
    Austin texas
    Posts
    She is A cb750k LTD 10th anniversary, single disk, I think the pressure is really weak, the break is spongy and has no grip what so ever it just gives way, how do I increase the pressure in the tube?
  4. #4
    CB750 Addict madmtnmotors's Avatar
    Join Date
    Apr 2015
    Sunny Central Florida
    Posts
    271
    Quote Originally Posted by Anthonyt View Post
    Sounds like the master cylinder could stand to be rebuilt. You can get new packing straight from Honda for a reasonable price:
    http://www.hondapartsnation.com/oemp...r-cylinder-set
    Might as well replace the dust seal and piston seal in the caliper while you're at it:
    http://www.hondapartsnation.com/oemp...9-425-003/boot
    http://www.hondapartsnation.com/oemp...04/seal-piston
    There's a chance that you still have original, thirty-seven year old seals in your brake system. Disassembly, thorough cleaning, and repacking with new seals can make a world of difference. While you're at it, jettison that thirty-seven year old dry rotted rubber brake line for either a braided stainless line, or at least a new rubber one. Might as well top it off with a new set of pads too.
    I know, I know, "everybody else is doing that way"...
    High price to pay for being "stylish"...
  5. #5
    Join Date
    Sep 2015
    Fort Worth TX.
    Posts
    2,909
    Like said, the master cylinder, humidity has gotten inside it. Probably will need to hone the body, and if corrosion damage is too deep then no seals on the planet will fix it. Commonly though you can get one hone/rebuild before the housing needs to be chucked. I have even reused the old seals if I can fold them all around to find zero cracks or corrosion dents and the rubber is still live. Reinstalled like that and hone only for no parts cost and the brake works for years. But then, I've done that type work so many times I can't count.
    I'd go through caliper too like said, whatever happened to M/C has happened to caliper too, it just hasn't failed yet.
  6. #6
    Join Date
    Aug 2016
    Austin texas
    Posts
    thanks madmtnmotors new break lines are shipping, I also replaced the fluid and there was some air in the lines. so the breaks are working till the new parts come!
  7. #7
    Join Date
    Sep 2015
    Fort Worth TX.
    Posts
    2,909
    They may work but with time the aluminum bore in the m/c gradually churns more and more corrosion bits into the system, once a bit of that stuff gets under a seal edge you lose it and instantly when it was working fine before. Why it's best to get in there to clean that all out and a quickie hone inside m/c and good and clean and you just bought yourself another 10 years of solid use with zero worries. The calipers generally not nearly so susceptible to that as the seals are quite a bit thicker.
Similar Threads
  1. VERY WEAK SPARK TO 2+3 CYL's
    By thesulman in forum The CB750 Garage
    Last Post: 02-07-2017, 12:16 PM
  2. I need a rear break caliper for a 78 cb750ss
    By cbkfam in forum The CB750 Garage
    Last Post: 10-01-2015, 12:59 PM
  3. Front Brake Weak and leaking
    By Jeff K in forum Frame / Suspension
    Last Post: 05-05-2015, 07:51 AM
  4. 78 Front wheel sticking using front brake........
    By T2rminator in forum The CB750 Garage
    Last Post: 12-14-2014, 07:12 PM
  5. Extremely weak front brake...
    By Stoney in forum The SOHC Garage (1969-1978)
    Last Post: 11-23-2013, 07:33 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
