78 750a Cylinder Head
it uses the same head as the 75,76F and the 77,78K head. Any of the heads can be used, the auto used a different piston, you will have to verify compression ration etc if you use the earlier heads. To much work is required to make the 77,78F head fit as it is a different animal then the standard 750 head
