Plug and play mono shock
Ridevana
7
Columbus, ohio
Hello all,
I was toying with the idea of mono shock rear end for my 78 SS. I have searched the forums here and other sites and most of them seem to have decided on certain swing arms and modified the frame to suite it. I plan not to touch the frame unless it is absolutely necessary (ofcourse I will be modifying it to adapt the mono shock) I was wondering if anybody knew about a plug-n-play swing arm from another bike that would fit the 78SOHC SS frame without any modifications to the pivot point and also the front and rear sprocket alignment?
I can work with aligning the sprockets by changing sprockets or adding offsets at the wheel/engine but not cutting the frame etc.
Any suggestion would be appreciated.
Thanks
www.ridevana.com
