nighthawking
Hey all, odd issue I think is carb related. Bike pops occasionally at fast idle, but general runs well with stock air and 4 into 2 with basically no baffles. Mains 68 and 105. At speed, say 30mph, if you let off the throttle, pull in the clutch completely, revs go down to idle fine. Still coasting, when you brake to stop, engine revs up as if it is getting fuel somehow, and you have to let out the clutch to bring the rpms back down and you can sit at the stop in idle. I thought it was float height too high related, but pulled the carbs and found the floats too low at 20mm or so and not all the same. Is the float height measured at the highest part of the float from the body? Has the run on happened to anybody? It is not cable related as this happens going in a straight line. Thanks.
