Results 1 to 7 of 7
  1. #1
    Forum Staff Travis's Avatar
    Join Date
    Feb 2012
    River Falls, WI, USA
    Posts
    1,023
    Video for checking valve clearances on the DOHC CB750
    Here's a good video for checking valve clearances on the DOHC CB750s. It's relevant for the Honda CB750, CB900, and CB1000. It doesn't cover the cam positions that well, but it shows you how to measure the clearances and remove the shims.
    - Travis
  2. #2
    CB750 Member Zero's Avatar
    Join Date
    Mar 2012
    Canada
    Posts
    26
    Great video Travis, thanks. I don't believe my '74 CB750 has ever been checked. It has 15k original miles, and once engine has run for a bit / operating temp the motor is strong. I've been told it probably needs rejetting more then anything which would help with starting and holding idle for the first bit. What's your thoughts?
  3. #3
    Moderator dirtdigger's Avatar
    Join Date
    Feb 2012
    Black Hawk SD
    Posts
    2,526
    Well my original factory Honda manual suggests adjusting valves every 3000miles, so....I think you may be over due
  4. #4
    Join Date
    Feb 2012
    Posts
    1,023
    Yeah I would at least check them to see if any are off, then decide if you want to order shims or can swap any around to get where you need to be.
    - Travis
  5. #5
    Join Date
    Feb 2012
    Black Hawk SD
    Posts
    2,526
    SOHC 750 have adjusting screws not shims
  6. #6
    Join Date
    Feb 2012
    Posts
    1,023
    Right. I didn't catch the '74 in Zero's post. I guess I figured since the video is about the process for the DOHC, that's what we were talking about. I should have read more carefully.
    Not that the process is hard, but maybe I can find a video for the SOHC bikes. Or make one.
    - Travis
  7. #7
    Join Date
    Mar 2012
    Canada
    Posts
    26
    wow, I'm probably well over due then. Thanks guys.
Similar Threads
  1. For Sale - DOHC CB750 Parts
    By witttom in forum Classifieds
    Last Post: 12-17-2012, 09:15 AM
  2. For Sale - Weisco 890cc (900cc) or 985cc Big Bore Kit for DOHC CB750 CB900
    Last Post: 06-08-2012, 04:43 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
