Could use a little help, issue with exhaust cam sprocket punch alignment!
flatpick13
24
Texas
I'm reinstalling my cams, with the crank at 1.4 - T and my exhaust cam installed with the #1 cylinder lobes pointed towards the spark plugs, I can see the sprocket punch marks above the head, but they don't align perfectly. They're probably closer to parallel with the floor than parallel with the head, but if I make the sprocket punches align perfectly with the head the lobes for the #2 cylinder are propped against the valve shims and the cam shaft isn't seated...
Anyone have any suggestions? Do the sprocket punch marks need to be perfectly aligned with the head? I'll grab some pictures and post in a follow-up to illustrate my predicament...
Need to be very careful when comparing head angle to the floor. Meaning your engine better be level like in bike.
Only new chains come close to lining up, if old they will be stretched and the cams slightly behind (retarded) then, meaning you could be correct there if looking at engine from the LEFT side. You have to install the cam caps to pull the cams down solid, there is no place on engine where at least one cylinder will not be hitting cam shims.
Try to split the head with the marks but if sprocket mark only seems to go in at too far counterclockwise or too far clockwise then use slightly too far clockwise as your ending spot. If not you will be in wrong by one tooth.
The chains stretch with use making the marks fall back, correct will be hitting the 1-4 mark and then you have to turn engine slightly a bit more (clockwise on ALTERNATOR SIDE of engine!) for marks to split head. That effect is worse the older the chains are. You do not use the left side of engine for turning it at all.
The exhaust chain stretches more as it is longer, the intake may be dead on or off less, but make it same way if there is any question.
Consider as well any lobes touching shims can shift cam around to alter what you see, why caps need to be in place for final check and the tensioners can too so multiple rechecks are need as you alter those things.
Thanks, amc. I got it lined up, had to pop the exhaust cam sprocket off while the cam bearing caps were installed so the cam didn’t shift while I lined the chain up. Kind of a pain getting the chain/sprocket back in place with the cam secured, but at least that parts done.
Follow up question, there were no rubber oil caps in the head when I opened it, I have some on order now, but what purpose do those serve and how important are they?
They direct oil slinging off chain and sprockets into the cam lobe pockets which fill with oil to let lobes dip into them to sling oil over parts. Whenever you rebuild top end you fill those pockets with oil just before cover goes back on.
I'm currently working on this too and would like to clarify your advice as I think you are referring to only one punch mark, the front one, but there are two. One on the sprocket close to the front of the engine and one on the other side of the sprocket closer to the back of the engine. When I install the exhaust cam and sprocket with the 1-4T lined up, the front punch mark is slightly above the head and the back punch mark is slightly below the head. If I then adjust by one tooth, then the front punch mark is slightly below the head and the back punch mark is slightly above the head.
Are you saying I should go with the first scenario? - front punch mark slightly above the head and the back slightly below the head?
What if I get the same with the intake cam sprocket? which would I choose there?
